What amp should I use for my current system - details in post
  • 1
InfinityAudio
Canada
Hope this is the right section.
I am currently running four Alpine Type R speakers and two 12 inch Infinity subs with a Kenwood Excelon Deck.
I had a 5 channel Craig Powerplay 500W amplifier running, but recently the remote wire terminal on the amp stopped working. I did some troubleshooting by switching my amp out with my friend's amp and his worked instantly so I know the wiring is fine and the amp must be fried or something. I even tried opening it up but couldn't find anything loose or wrong inside.
Anyways, what amp should I get to run this system? I've been learning as I've been building the system so I don't know everything about car audio and now I want to get some opinions and advice before I buy another amp.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
Have you check to see if the prefab would fit...
13
For the sub you want to run.. The 700.1 will be more than enough power and enough Head room for that sub. For the Price? And the sub you are...
13
Your skar amp will catch on fire if you go full power?
8
I'll suggest a JP8 amplifier. I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct? JP8 @ 2 ohm does 900 watts.
InfinityAudio
InfinityAudio
Canada
InfinityAudio
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
