Amp for my jl 12w6v2?
  • 2
fontanaaa
So I just got a jl audio 12w6v2 sub for my truck and I am having trouble deciding on the right amp. I've been looking at 3 main options but I am open for any suggestions.
Option 1: PIONEER GM-D8400M
PIONEER GM-D8400M 1200 WATT MONO CAR AMPLIFIER AMP - eBay (item 390221734181 end time Aug-02-10 06:55:53 PDT)
Option 2: KICKER 08 ZX750.1 750W
KICKER 08 ZX750.1 750W CLASS D AMP MONOBLOCK AMPLIFIER: eBay Motors (item 400132733992 end time Jul-29-10 20:54:35 PDT)
Option 3: JL 500/1
500/1 JL AUDIO 1 CH SUB AMP MONO 500 WATT AMPLIFIER NEW - eBay (item 120596922041 end time Aug-15-10 17:50:58 PDT)
I would be buying the 500/1 used because its out of my price range so what do you think?
give us a budget... you can buy more power for cheaper.. Look at less Mainstream try Audiopipe amps, MB Quart, AQ 1200d isnt to expensive good amp to. Look in the classifieds here.
See I'm afraid to stray away from mainstream products because I know you get what you pay for in the long run usually. I'd say my price range is about 100-250
people on here have had amps from MB and AQ for years. Most of the time it's user error if an amp fails.. I.e. ABusing it sending it into protect multiple times etc..
We personally don't buy JL because they cost an arm and a leg. i have nothing against JL. It is a good brand but not worth the price imho..
Kicker is eh for me they run hot and i like 1 ohm stable amps..
I tend to stay away from anything pioneer unless its a Headunit..
Research some things. Audiopipe 1500d's will run you $150 and do rated.
yes just make sure you set your gains right. It is really good to have headroom when buying amps.. FOr instance buying a 1000 watt amp for a 600 watt sub. Its just good to have the extra power. Make sure you know how to set your gains.. The amp will only put out as much as you set it to.. For example i have 2200 watt amp and only use 1000 watts of it.
yes im guessing you don't have a lot of experience installing equipment. Not flaming you just wouldn't want you to spend money then blow it all on installation error. Take it a shop and tell them to set the amp settings.. I was just like you a couple months but this site helped me a lot actually lol just make sure to do your research before making decisions. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Hope im helping
Unfortunately yes they do //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif maybe some in your area on here could help you for a hell of a lot cheaper price. Some people on here would be glad to help.
Ok well thanks a bunch for all your help..i may be contacting you again in the near future //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Ive done by ear for so many years and so far havent had any issues this way,,, So Far.LOL. The DMM method is one of the safest ways to do it,or...
I was looking at a stinger spp680 but i worry its not enough for 1300 watts. The company site says it is. I see other sites saying onky up to 800...
18
185
386
483
fontanaaa
fontanaaa
Tallahassee
Maxipads
