Amp need for 800-1000 wrms 1 ohm.
Here I go again, CROSSFIRE VR1000D:yumyum:
Nice, nice, nice, nice....
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
^ I second the Hifonics decision. If you want to spend the money get something more but for the money you cant beat it I dont think. I love my older BX1000D and know for a fact it does a good 900 watts at 1 ohm so even though they may be overated, they still do close to their power at 1 ohm. Also im sure they can do more than rated power if wired below their minimum ohm ratings. My BX1000D runs my DP @1 ohm and never breaks a sweat, even in the summertime in direct sunlight and I wouldnt hesitate to run it @ .5 ohm with conservative volume usage.
proof of this power? bc i know the 1500d did like 1150-1200 with 5%+ thd.
newer models are much better though (05 and 06)
Eh..the fact that at a 1ohm resistive load my amp pumps out a stable 31 volts rms @60 hz at 13.5 volts input. Im not saying that wont drop due to impedence rise from the subwoofer but while hooked up to my DP @1 ohm it can push 32 volts rms @ 60hz just before audible clipping so im more than happy with it. And since you might even call BS on that..with a 105 amp alternator and no accessories running it can produce a very small voltage drop while cruising at highway speeds. So im confident it can do it.
964
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
wcarson8911
wcarson8911
Little Rock, AR
80_Cutlass_mn
