Amp not working Advice
  • 2
lliamiskool
CarAudio.com Recruit
Hi all, I am still fairly new to car audio, so I figured I'd come to the experts. I have a boss head unit and a sound ordanence 8" powered sub that work great. I recently picked up a mtx 12" sub that is 24 years old, and a bazooka ela500.1. I wired it the same as my powered subwoofer, and used regular old speaker wire to connect the sub to the amp. I have no idea how to tune it so I left "level" at min, "x-over" at 40 hz which is the lowest, and "bass boost" at 0. When I turn on my radio, the red power light turns on briefly then shuts off. Any ideas? Could the way I have it tuned be doing this? Or is speaker wire too thin? Any advice would be much appreciated.
The amp should still turn on regardless of your settings. Those settings will probably cause almost no power to come from the amp, but thats a discussion for when the amp will actually stay on, lol. Is the amp also 24 year old? It could just be damaged. Double check all of your connections. Then I would use a multimeter to check the voltage at the amp and measure the resistance from the ground terminal to the vehicle body.
There isn't much it can be. Pull the amp turn on wire out of the amp, and just run a wire from there and touch the distro block will activate...
Some equipment like AMPS comes with it no owner's manual. So the lights blinking on or off has to be taken somewhere else. Search engine. Car...
I updated the original post to simplify it a bit and re-frame it with the new Scosche floating ground adapter. This adapter *is* different, as it...
I’d suggest taking a methodical approach. Start with things you know work. Then add one thing at a time. Test the addition with a scope. Keep...
181
lliamiskool
lliamiskool
New Jersey
SbassLaser
SPLBassJunkie
    May 21, 2024
    May 20, 2024
