One speaker working at at a time with new amp. Please help!
  • 2
BryceCC
CarAudio.com Newbie
Hello, I am relatively new to car audio and decided to install an aftermarket amp, front door speakers, and subwoofer into my car. I was on a budget and decided to get a 4-channel amplifier and bridge the rear channels to the subwoofer and front channels to the front door speakers. I have a 2010 Hyundai Tucson GLS with a premium factory audio system that has a stock amplifier and stock subwoofer. The subwoofer unfortunately has never worked and I still don't know why. I didn't want to change the stereo because there is nothing wrong with mine and it has Bluetooth and a touch screen which is all I need. So I decided to buy a LOC to tap into the front speaker outputs on my stock amplifier to get the RCA's going into the new amp. After wiring everything I got the subwoofer working but when I would connect my front door speakers to the amp only one of them would work. I tried switching the RCAs and even adding another LOC that taps into the rear speaker outputs on the amp so I could eliminate the Y splitter at the amp. None of this has worked and I am genuinely stuck on what I should be doing. At this point, all I could think of is it was the amp not working or the LOC. I could just be doing something wrong but I'm not sure so that's why I'm here. If I have to get a new amp would it be better to get a different 4-channel amp or get both a 2-channel amp and mono amp for the sub, not sure? Any help would be much appreciated. Also, I know people hate Blaupunkt but I thought 70 RMS per channel would pretty good for $70 and what parts I have. Thanks! Parts and pictures are below.
Blaupunkt 1500W 4-Channel, Full-Range Amplifier
Skar Audio IX-12 D4 12" 500 Watt Max Power Dual 4 Ohm Car Subwoofer
Kicker KISLOC 2-Channel K-Series Speaker Cable to RCA Adapter with Line Out Converter
Kicker 47KSC6704
I’d suggest taking a methodical approach. Start with things you know work. Then add one thing at a time. Test the addition with a scope. Keep adding until it doesn’t work. Then you have the problem.
Say start with rear speakers. They work then add in the splice. Test it with a scope. That works? Add loc and test that. If that doesn’t work. Then replace the loc. preferably with an active loc. it’s a little more wiring but worth it.
Its lasted 19 years thus far. Could be something as simple as a wiring connection as stated. Nothing in electronics last forever. Its had a great...
8
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
216
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
310
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
263
BryceCC
CarAudio.com Newbie
BryceCC
United States
Glen Livet
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
