Amp not working
ashtrey
17
USA
I've installed a new headunit and the amp powering my speakers isn't working at all no power light no protect light all the fuses are fine I haven't checked the actual car fuses yet but the amp that's powering my subs is working just fine and I can hear the bass and I have no idea why this is happening cause both main power wires are connected to the same wire through a distro block and I've tried daisy chaining the ignition wire from the working amp to the not working one and still subs work but speakers don't
I'm also using speaker wire to rca adapters cause the new one doesn't have RCA outputs
The amp should still turn on regardless of your settings. Those settings will probably cause almost no power to come from the amp, but thats a...
Some equipment like AMPS comes with it no owner's manual. So the lights blinking on or off has to be taken somewhere else. Search engine. Car...
I updated the original post to simplify it a bit and re-frame it with the new Scosche floating ground adapter. This adapter *is* different, as it...
I’d suggest taking a methodical approach. Start with things you know work. Then add one thing at a time. Test the addition with a scope. Keep...
180
ashtrey
ashtrey
USA
HardofWhoring
SPLBassJunkie
    May 21, 2024
    May 20, 2024
