amp protection mode at high volume
  • 2
skullsmasher88
hello hope you guys can help.
i have a 1100 watt Sony xplode 2 subs that are dual 2omh 1200 watt Rockford fosgates p3
okay so the problem is when i put the volume up amp goes in protection mode.
things i already tried:
find a better/different ground
un plug rca and see if it still goes in protection mode (it doesn't)
wire subs in different ways + to +s - to -s, and tried tie both positives and negitive together and put + on one and - on one.
also try turning down gain bass boost still goes in protection mode.
so made me think i have a bad sub so i hook only one sub up works prefect i try the other work perfect.
is it because subs need more power then amp is giving?
Ok thank you, I'll check where the remote wire is connected and get back to you.
Ill try it when I get the amp back, especially if the forbidden protect light goes on. I don't think it's grounding out anywhere because I still...
8
Make it look nicer. Carpet it up with black. It will look like a speaker. The wood look is not good at all. Don't look too professional. What...
39
6K
Not much user serviceable about an amp powering up into protect with nothing else connected. Send it back for repair/exchange or whatever they do...
Thank you for the info and advice. I really appreciate the help. I will double check my wiring tonight or tomorrow.
20
4K
skullsmasher88
skullsmasher88
illinoise
CrossoverOre
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
