Assistance with electrical connections requested.
  • 2
i2ain2thunder
6
st paul, mn
Hi guys. I've had my current setup for about a year now. I don't have the money to do any major upgrades or changes for a while. But I would like to look into something that may be a limiting factor in my system, that I could possibly fix up on the cheap. That would be my connections.
Heres what I got for connections:
1/0 Big 3 (to standard OEM - and + locations).
1/0 from + on Optima Yellowtop to Amplifiers.
1/0 and 4 gauge runs from Amps - to trunk ground. (found a bolt to use that connects to the trunk chasis.) Red paint was sanded from that spot for a more optimal ground.
Here's my initial problems.
1 age, it seems about all of the connections in the engine and the ground in the trunk over time become worse with corrosion/rusting/oxidizing etc.
When I go through and redo my connections I usually just end up scratching everything I can with a wire brush or sandpaper.
What are some of the things you guys do to keep these connections clean over time, and should I find a better ground for my amps (until I can afford another yellowtop for the rear (parallel with a dedicated ground run).
Is there a certain type of metal u look for in your ring connectors?
Do you seal connections with silicone or something similar?
Should I be looking to get different bolts that go into these connection spots? Put a certain type of washer on? Use any dielectric grease?
Just to give you guys a quick peak at it I took some phots quickly:
I apologize for the poor quality, but just to give you an idea how bad some of my connections are:
Battery:
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
490
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
i2ain2thunder
i2ain2thunder
st paul, mn
CrossoverOre
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
