Amp questions!
  • 3
lipski24.ml
Wisconsin
So I am looking to buy an audiopipe apsm1300 and maybe two kewood kfc-w2513ps subs with it. Now the amp ratings say 1x 600x 2ohms. So does that mean it won't power both subs correctly? I am confused! Oh and do you think that an 8 guage audiopipe wiring kit will work well with this amp? Thanks again for helping with all my stupid questions! I'm only 15 and new to everything but yet I know a good deal for my age!
That means of.u wire the subs at 2 ohms each sub will roughly get 300rms ....best bet is to run that amp at 1ohm does close to 1000rms cleanly ..also u will need at least a solid 4 gauge kit.to run that amp
Okay! How would I run two SVC subs at 1 ohm though? I know how to wire down to two ohms. But idk about under that! And alright! I will get a different wiring kit!
Yea true ..forgot those kenwoods were svc ..i would try to find some decent 500-600rms dvc 4ohm subs so u can wire to 1 ohm ..u will be so much more pleased with that setup
I am really tight on money so I am just going to say screw it for now! But thanks for the help! Already picked out the other amp wiring kit for a better price! So I can't wait to get it with the amp! Thanks again!
Havent run or heard anyone with those amps but on the power wire for sure go with 4 gauge or bigger cause itll save you money on the long run i just make those mistakes..
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
two d2 subs can be wired to .5 or 2 or 8 ohms not 1 heres how to wire subs...
From what I've read, LiFePO4 works with lead acid, LTO does not. I have only personally tried LiFePO4. I personally can't justify the extra hassle...
hi all, thanks for allowing me to join your site. im installing 2 soundstream tx4.560 4 channel amps, but i want to run them as 2 channel...
6
75
lipski24.ml
lipski24.ml
Wisconsin
stereoguy
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
