Amp suggestion for a pair of JL 13w7's?
  • 4
urnvs
I have a pair of 13W7's running off a bridged Kicker KX2500.1 and it is cutting out when the really low stuff hits. Im looking for a suggestion for an efficient amp(s) to replace this one, that will really push these speakers to the limit.
So your prolly running the amp at 1.5 ohms I'd guess which shouldn't be an issue for the kicker. So either there is an electrical issue here or a bad amp But if the amp plays fine except when that heavy bass note hits. I'd more likely think it's a power issue. What alt and what batts ?
Yes, 1.5 ohms which is actually lower than the 2 ohms Kicker recommends. Mechman alternator and Deka AGM batteries.
Dont get me wrong, it hits loud as hell before cutting out, but I just feel that there is still more room to go as its not really sounding distorted.
Check voltage at the amp when it cuts out. Also check for loose connections in all the wires. It maybe something real simple Rule out all possibilities before you replace the amp
Great bang for the Buck/ Have (2)2ks and a 150.4. great amps for the Coin Thus far.A little head room doesnt usually hurt...
5
6
136
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
316
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
311
urnvs
urnvs
Phoenix, AZ
bumpasauras
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
