Amp suggestion for a pair of JL 13w7's?
  • 4
urnvs
I have a pair of 13W7's running off a bridged Kicker KX2500.1 and it is cutting out when the really low stuff hits. Im looking for a suggestion for an efficient amp(s) to replace this one, that will really push these speakers to the limit.
So your prolly running the amp at 1.5 ohms I'd guess which shouldn't be an issue for the kicker. So either there is an electrical issue here or a bad amp But if the amp plays fine except when that heavy bass note hits. I'd more likely think it's a power issue. What alt and what batts ?
Yes, 1.5 ohms which is actually lower than the 2 ohms Kicker recommends. Mechman alternator and Deka AGM batteries.
Dont get me wrong, it hits loud as hell before cutting out, but I just feel that there is still more room to go as its not really sounding distorted.
Check voltage at the amp when it cuts out. Also check for loose connections in all the wires. It maybe something real simple Rule out all possibilities before you replace the amp
Great bang for the Buck/ Have (2)2ks and a 150.4. great amps for the Coin Thus far.A little head room doesnt usually hurt...
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
226
urnvs
urnvs
Phoenix, AZ
bumpasauras
