annoying window rattle
  • 3
my windows are constanly rattling loose from the closed/ rolled up postion from vibrations due to bass and when they do it makes an ungodly rattling noise, anybody had this problem, and have a soulution/fix?
depends on the vehicle but start by pulling the door and seeing how the window is secured in the tracks and see if you can add stiffer padding like felt tape
hmmmm i didn't think about that, il will give that a try...thanks for the fast reply!
The vibrations probably caused the wires to rub against metal somewhere...that takes time 😂
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
Example. H.depot or Lowes should have some also? or a hardware store
9
Sprinkin8tor
Sprinkin8tor
Easley, SC
Eggroll
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
