Sprinkin8tor
my windows are constanly rattling loose from the closed/ rolled up postion from vibrations due to bass and when they do it makes an ungodly rattling noise, anybody had this problem, and have a soulution/fix?
depends on the vehicle but start by pulling the door and seeing how the window is secured in the tracks and see if you can add stiffer padding like felt tapemy windows are constanly rattling loose from the closed/ rolled up postion from vibrations due to bass and when they do it makes an ungodly rattling noise, anybody had this problem, and have a soulution/fix?
hmmmm i didn't think about that, il will give that a try...thanks for the fast reply!depends on the vehicle but start by pulling the door and seeing how the window is secured in the tracks and see if you can add stiffer padding like felt tape
Or weather strippingdepends on the vehicle but start by pulling the door and seeing how the window is secured in the tracks and see if you can add stiffer padding like felt tape
