Umm yes they do. One must always seal the front of a woofer from the rear as the rear wave is 180 degrees out of phase with the front. By not sealing it off you run the risk of that rear wave canceling out parts of the front wave. This is not to be confused with sealing them in an enclosure however as this is an infinite baffle situation. This is why you see everyone who is running an infinite baffle setup in their vehicle going through the trouble to seal all of the holes around the baffle to which their sub(s) are mounted.What do you mean by bad bass? They still sounded good to me. They dont exactly need to sealed, but I get your point......
Didnt paint the tweeter pods because the guy said he wasnt concerned about "show quality". If he bought the paint to match....then I would do it. If given the right materials and requests by customers, ill do it.
This is true. Got results of how much cancellation would be had from a 1/4" gap that isnt all the way around the speaker?Umm yes they do. One must always seal the front of a woofer from the rear as the rear wave is 180 degrees out of phase with the front. By not sealing it off you run the risk of that rear wave canceling out parts of the front wave. This is not to be confused with sealing them in an enclosure however as this is an infinite baffle situation. This is why you see everyone who is running an infinite baffle setup in their vehicle going through the trouble to seal all of the holes around the baffle to which their sub(s) are mounted.
Taped? You should be using marine grade heat shrink that will last a lot longer than tape. Just some advice.All connections were soldered and taped. I dont have pics of it tho. I just wanted to get the main pics. I told the guy it would look cleaner to mount the antenna inside the car instead of on the roof. Plus, it saved some time.
First off, can you even use heat shrink on a connection that you "tapped'? If so, explain. If installing an alarm and/or remote starter or anything else that you just tap into wires, id like to know how do you heat shrink it without actually cutting the wire in half to slip on the heat shrink.Taped? You should be using marine grade heat shrink that will last a lot longer than tape. Just some advice.
