Anroid Auto and Kenwood DNX997XR Navigation problems
STIEJ19
CarAudio.com Newbie
USA
For month's I've been dealing issues with Android Auto and my Kenwood DNX997XR Navigation system. The screen seems to suddenly refuse to function and appears as if someone is hitting buttons and the screen constantly. This occurs even if Android Auto is not connected, even after doing a factor reset on the stereo, re-pairing my phone and stereo, both in wireless and wired Android Auto modes. Below are 2 videos I took of this issue. Any help would be greatly appreciated!
https://photos.app.goo.gl/wEYNUkG19Zynx2L56
Has the screen been sprayed with a cleaner?
I was gonna say the same thing. Possible water damage. Even enough condensation could do it.
Do the physical buttons work while it's acting up?
Another thing that causes capacitive screens to act up like is stuff on the screen. Try cleaning it with a alcohol pad. Any moisture, oils or grease on the screen could register as a touch.
If that's not it, could be loose connection or bad digitizer. Sometimes a ground issue could cause it. Tape inside fell off. Might have to open it to check the screen connection.
Hope there's a warranty.
We have touch screen registers at work
Crumbs and whatever else you can imagine from fast food places gets stuck in the trim around the edge and they start to act like they are possessed
I have to take the trim bezels off once a week and clean under them to prevent it from happening
I have the exact same unit in my truck and been having the same issue for about 3 months. I also tried a hard reset, cleaning the touchscreen and a couple of other things. Just did a google search for ideas and found your post. I'm thinking it's an issue with the touchscreen itself?
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
Ugh yeah it can use Android Auto and Google Maps says so right in the manual. Alpine is good about that stuff with integrating not only ugh Apple...
STIEJ19
CarAudio.com Newbie
STIEJ19
USA
hispls
Doxquzme
    May 10, 2024
3toneEYZ
    May 10, 2024
