any body want to see the new ab hybrid mini
i'll try here
rated power 120 x 4 at 4 ohm max 150 x 4 at 2 ohms
impedance 4 ohm stereo , bridged . 2 ohm stereo
input sensitivity 6v-0.2 v
hp filter 50 hrtz - 5khz
lp filter 50hz-500hz
subsonic filter na
bass boost na
frequency response 20-20khz
snr 105
efficiency over 65 %
thd @4 ohms
damping factor 150
fuse rating 40a
dimensions 11.417 " x 6.496" x 2.244 "
well got my 2 ab vfl 4480 mini's today will take pics tomorrow to show you guys.they are about 13" long and just over 2200 watts rms at 1 ohm.got it running at .7 right now and sounds great .now i just need to get a maxx link so i can install the second one.one on each pair of my dd 1508 subs should be nice. just rebuilt the box too,so now i have 4 total subs going,hits nice.pics tomorrow.//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
My concern with A/B mini amplifiers is always heat. At least the large ones have a large heat sink to dissipate the heat. Just because the amplifier is small, this does not make all the heat generated by inefficient Class A/B technology will go away. It will stay. I have an MB Quart REF4.80, which can be classified as mini. The thing runs very hot and will go into thermal shutdown if there is something in the trunk that can obstruct air flow near it, even though all channels are running at 4ohm with two channels powering tweeters(!) and two others powering mids. A lot of people running Massive Audio nano series minis have issues with heat too. Nothing is more embarrassing than have the stereo shutdown 30 minutes after turned on on a long trip with buddies because the trunk is filled with luggage.
View attachment 26537256View attachment 26537257View attachment 26537258View attachment 26537259View attachment 26537260
i hear ya on this one but so far these dont get hot at all ,not even warm yet
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
11
Contact ANS he has a used Focal 8 Channel DSP that went for 1,300 bucks and is selling used I think shipped for 450. And from what I have seen and...
13
Actually, I was wrong, it was to go into his 1972 Currier! The 4runner just wasn't workable and he ended up getting a high performance motor...
28
3K
I don't think OP is going to do the deadener themself, but these are my tools for it. If its 80 degrees out, you can just leave it out and it's...
7
4K
mylows10
B2,singer,ampere rep
mylows10
monterey , ca
mylows10
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
