any simple tests to tell if component set is out of phase
  • 4
sometimes there's manufacturer defects where polarity is switched. Happened to me with a set once.
the terminals may be swapped, but I was talking about the voice coil. the positive lead is always the left leg of the coil
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
I went with those simply because they fit, the cutout is round, and the hole will take a 6.5 coax. Cutting a square hole in a boat for a speaker...
21
5K
I think you're going to find this is true across the board. Technology has come so far at this point that even the absolute rock bottom unit that...
6
I would run a pair of 15s in an suv.. or run 4) 12s
24
3K
No Issues out of my CT Sounds amps..EQ, 6.5s. There is not one company out there that hast ever had a perfect QC run that I can think of.Hard to...
8
corto
corto
Flint, Michigan, United States
corto
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
