are 4.7 cubes enough for 2 12 inch l7
  • 5
L7's love larger enclosures.
If you are actually getting 4.7 after displacements won't be to bad...depends on a few things..but all in all shouldn't be that bad. Much better then those prefabs for them.
Thanks guys for the help is a 35 hz tune for rap music okay or is it too high?
It should be fine, your subs will still play frequencies a little lower than the tuning with authority. I like to set my subsonic filter to 10Hz below my tuning point and my subs still hit hard until they reach the point of the filter.
It just occurred to me that I need to mount two twelve's and the widest I can make the port is 4 inches and 13 high what would my length have to be
If the box is 34 inches wide and you mount 2 12" subs you'll have 10 inches left (8.5 after counting the thickness of the MDF on the port walls). The subs lip just has to be even or close with the side of the box and the two subs have to be really close to each other
Can the port have triangle braces in it or will that create noise because I wanna use the right wall as on side of the port to save room but I have two trangle braces on that wall already what should I do
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
3K
Bomtillington
Bomtillington
Rhode island
Bomtillington
Decebal
    Jun 10, 2024
