Audiobahn A5000spl
  • 4
audioman14
$1200 Obo
I have had this Audiobahn Amplifier in my closet for many years and have never hooked it up or tested it. I know that sounds far fetched, but I honestly have never tried to see what crazy power this thing puts out due to not obtaining speakers powerful enough to put to the test. I listed this item as "New-Other" because I do not have the Instructions Manual and the bass knob that came with it originally, But you can find the Instructions Manual at Manualslib's website and the Bass Knob/Controller on Ebay for around $25.
SPECIFICATIONS
1 Channel High Current Power SPL Amplifier! 1x 4000 watts RMS @ 2 ohms mono 1x 5000 watts RMS @ 1 ohm mono The power is measured at 12.5 Volt/1kHz Var. 24dB low pass 50Hz - 120Hz Bass Boost 0-18dB at 40Hz - 100Hz Subsonic 20Hz - 50Hz Phase Shift 0 - 180 Power 400 - 450 amps Input sensitivity 0,2 - 10V Maximum input voltage of 18 V voltmeter 2x 50mm ² power 1x 25mm ² speaker terminals Digital Voltmeter 6x fan, Cobalt Blue Illumination LED level display Dimensions (LxWxH): 15 3/4 x 12 x 10 inch Features: + Type: Amplifier + Number of Outputs: 1
Competition amplifiers are able to provide power output like no other amplifier. They perform when you need them to and at a competition level. The A5000SPL by Audiobahn is a 5000 watt monoblock amplifier that will give your subwoofers a serious boost. It is rack mountable wit hall the necessary controls and dials right on the front. There is a digital A/C output voltage display on the front to keep you informed. The blue lights are sure to please any spectators. 6 Fans on the back will keep this monster cool, even during some extreme use. Factor in the price and you got a monster amp for a killer deal!
Single-Channel Momoblock Class D SPL Competition Car Amplifier
RMS Power Rating:
4 ohms: 4000 watts x 1 chan.
Bridged, 4 ohms: 5000 watts x 1 chan.
Max power output: 5000 watts x 1 chan.
Full MOSFET power supply
Wired remote bass level control included
Blue LED indicators
Tuned Bass EQ (0-18 dB bass boost)
Thermal, short circuit, overload protection
Rack mountable
LED Clipping indicators
Preamp RCA outputs
Up to 18V DC input
Stable at 1 Ohm
Heavy duty aluminum alloy heatsink and 6 cooling fans for extreme heat dissipation
RCA level inputs
Screw terminals
Variable low-pass filter (50-120 Hz)
Subsonic Filter (20-50 Hz)
Dimensions: 15-13/16"L x 11-15/16"W x 10"H
FYI.. These are not a Car shaking sub.. But these will give you some pretty nice bass in almost any vehicle that has nothing at all. Best placed...
audioman14
audioman14
Washington, D.C.
a1mcalister1
    May 18, 2024
    May 16, 2024
