Tarmaps HD15000 1ohm
  • 2
Omegakan
boston ma
//content.invisioncic.com/y282845/monthly_2018_08/1061349846_taramps3.jpg.5c6be72eee8badcb78c90a1f06395d63.jpg
View Listing
1. Product:
Taramps HD15000
1ohm model
2. Specs:
LineLine HDReferenceHD15000 - 1 OHMOperation
ClassClass D
Number of Channels01Max Output Power@ 14,4VDC - 1 OHM: 15000W RMS@ 14,4VDC - 2 OHMS:10920W RMS Input Sensitivity220mV @ -13,15 dBmSignal Noise/Ratio˃ 95dBFrequency ResponseFull Range: -3dB @ 10Hz to 10KHzCrossover High Pass (HPF)10Hz to 80Hz (-12dB/Oct) VariableCrossover Low Pass (LPF)80Hz to 10KHz (-12dB/Oct) VariableInput Impedance18K OHMSProtection SystemShort-Circuit to Output / High / Low Supply Voltage - Thermal ProtectionMaximum Supply Voltage16 VDCIdle Consumption3,6AMusical Maximum Consumption@ 14,4 VDC: 648,5ASinusoidal Signal Maximum Consumption@ 14,4 VDC: 1297ADimensions (WxHxD)268,7 x 72 x 519mm
3. Description/Condition:
Used. In great shape.
I have had this for a couple of years but it only has a hundred or so hours on it.
Ran it at 4 ohm its whole life powered by 5 group 24 batteries and a 240 amp singer alternator.
4. Price: :
750 shipped to the lower 48.
5. Pictures:
See attachments.
Bump. I know this is a tough time to sell because of the holidays, but I am dropping the price significantly. 750 or best reasonable offer. Let's go.
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
Shipped from Amazon so its legit. Used it once before for something else and no issues.
12
  • Locked
GM-D9701. Used it to power a sound quality sub (Adire Brahma 15”). Was adult owned and carefully used (had a Mini DSP connected to it with a...
Omegakan
Omegakan
boston ma
Omegakan
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
