Audiobahn A5000spl
  • 4
audioman14
$1200 Obo
I have had this Audiobahn Amplifier in my closet for many years and have never hooked it up or tested it. I know that sounds far fetched, but I honestly have never tried to see what crazy power this thing puts out due to not obtaining speakers powerful enough to put to the test. I listed this item as "New-Other" because I do not have the Instructions Manual and the bass knob that came with it originally, But you can find the Instructions Manual at Manualslib's website and the Bass Knob/Controller on Ebay for around $25.
SPECIFICATIONS
1 Channel High Current Power SPL Amplifier! 1x 4000 watts RMS @ 2 ohms mono 1x 5000 watts RMS @ 1 ohm mono The power is measured at 12.5 Volt/1kHz Var. 24dB low pass 50Hz - 120Hz Bass Boost 0-18dB at 40Hz - 100Hz Subsonic 20Hz - 50Hz Phase Shift 0 - 180 Power 400 - 450 amps Input sensitivity 0,2 - 10V Maximum input voltage of 18 V voltmeter 2x 50mm ² power 1x 25mm ² speaker terminals Digital Voltmeter 6x fan, Cobalt Blue Illumination LED level display Dimensions (LxWxH): 15 3/4 x 12 x 10 inch Features: + Type: Amplifier + Number of Outputs: 1
Competition amplifiers are able to provide power output like no other amplifier. They perform when you need them to and at a competition level. The A5000SPL by Audiobahn is a 5000 watt monoblock amplifier that will give your subwoofers a serious boost. It is rack mountable wit hall the necessary controls and dials right on the front. There is a digital A/C output voltage display on the front to keep you informed. The blue lights are sure to please any spectators. 6 Fans on the back will keep this monster cool, even during some extreme use. Factor in the price and you got a monster amp for a killer deal!
Single-Channel Momoblock Class D SPL Competition Car Amplifier
RMS Power Rating:
4 ohms: 4000 watts x 1 chan.
Bridged, 4 ohms: 5000 watts x 1 chan.
Max power output: 5000 watts x 1 chan.
Full MOSFET power supply
Wired remote bass level control included
Blue LED indicators
Tuned Bass EQ (0-18 dB bass boost)
Thermal, short circuit, overload protection
Rack mountable
LED Clipping indicators
Preamp RCA outputs
Up to 18V DC input
Stable at 1 Ohm
Heavy duty aluminum alloy heatsink and 6 cooling fans for extreme heat dissipation
RCA level inputs
Screw terminals
Variable low-pass filter (50-120 Hz)
Subsonic Filter (20-50 Hz)
Dimensions: 15-13/16"L x 11-15/16"W x 10"H
FYI.. These are not a Car shaking sub.. But these will give you some pretty nice bass in almost any vehicle that has nothing at all. Best placed...
5
audioman14
audioman14
Washington, D.C.
a1mcalister1
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
