Avalon 2005 headunit replaced - anyone have data sheet/specs for wires on the amp under the passenger seat?
  • 1
gleep52
I put in a Kenwood carplay head unit years ago and it's worked fine. I have the JBL system and I use a Metra TYTO-01 JBL Amplifier Interface Harness to go from high level speaker outputs on the kenwood HU to the Metra harness which then goes to the factory radio harness and feeds into the factory amp under the passenger front seat. I also have the idatalink maestro RR for steering wheel controls, etc.
I'm looking to upgrade my headunit again - trying to decide between a Pioneer and Kenwood head unit with wireless carplay - and perhaps upgrade the factory amp and bypass the Metra harness/factory amp. I want to get rid of the metra harness because I've gone through two already - they work great for a year and eventually start cutting out sound on random speakers unless I shake the adapter box and then the speakers will start working again. I'm assuming this is a known issue because each time I replace the box (don't mess with any wires, just unplug and plug in the harnesses to the box) it works great for a year. I think it's the massive temp changes that eventually wear these little 40-50 dollar boxes out. Anyway - I figured a nice 4 channel amp would probably fit under the passenger seat and I can remove the factory amp - and just use RCAs straight from the head unit to the new 4 channel amp. But I have no idea which wires go to which speaker on the factory amp, etc... Is the box under the passenger seat MORE than just a factory amp - or can I completely remove it and use that space for a new 4 channel amp?
The factory amp has three large wire harness connectors with a lot of wires... I believe my car has some crazy number of speakers - so I'd have to combine say the left tweeter and woofer into a single channel on the new amp. Just hoping someone had some instructions or documentations on which wire is which to see if this was even possible, and if I can remove the factory amp - or if it is somehow needed for something silly like the factory head unit (which is relocated to my trunk so my climate controls still work).
Thanks in advance!
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
12
667
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
6
975
https://www.sonicelectronix.com/ci95-2005-buick-lacrosse-wiring-harness-to-install-a-new-car-stereo.html?sort_order=price_asc lots of options...
6
Can anyone in here participate in a short interview I am doing for school about the installation of a Kenwood DMX4070S in my 2005 Ford Expedition...
what ^ said. amp gain setting info, test tones are at the very bottom...
417
gleep52
gleep52
Colona, IL
gleep52
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
