bad feedback?
i changed the rcas already and it still done it. It was working perfact all i did was move the box up behind my front seats and mount the amp on the back of the box and when i hooked it back up it started doing it.
Take that hu out, walk over to the trash can, and drop it in, and close the lid...Good riddens, and find an eclipse HU, that will last and get your moneys worth.IMO
OP take a wire and strip it down all the way and tightly wrap it around all of the RCA shields coming out of the back of the headunit, then attach the wire to one of the screws on the headunit casing. What's happening is the ground signal on the RCA's is different and because the ground signal isn't equal you get feedback.
That's why I said it really depends on the sub 😂
16
Bonjour et bienvenue à mon ami d'outre-Atlantique! Need a lot more info on what the goal is and what you are working with. What car? Did it come...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
9
All that carpet will have to be ripped out and replaced. There is no other way around it to get it done properly. Seal both sides of the...
17
aaronwhitlock3
Hodgenville, KY
disturbed471985
