Bad Terminal Cup
  • 4
cam1134
I've been using pre-fab boxes for a while and love the simplicity of terminal cups but the past two times I've used them they've quit working.
The first one just quit working one day. It shows no visible signs of any reasons of why it wouldn't work and I get power all the way up to the terminal but it just doesn't conduct through to the other side. The same thing happened to another cup that I took out of an old box I don't use and the same thing happened to it in about two months.
I've solved the problem by just running my speaker wire from my amp to my sub through the port on the box but I just hate the way it looks.
Can anyone explain why this is happening?
Thanks!
Terminal cups are cheap and will break because they are not meant for the power we sent through them. A couple alternatives you have is drill a hole in the box where you need the wire to go through and then silicone it from the inside to seal it, or you could run a bolt through the box and put some ring terminals on your speaker wire then just bolt the terminals on either side of the bolt. This is nice because if you set it up right you can switch around your wiring options real easily by just rearranging the wires
i have also had issues with cheap terminal cups over the years. bolts are great - just double-up on nuts so they don't want to turn. two wrenches will allow you to tighten the pair of nuts (ha!) and prevent the bolt from turning.
My 2 - 15" wedge box is around 5 cubes net with 80 square inches of port. My 4 - 8" wedge box is 3.69 cubes net with 43¾" square inches of port.
7
422
Bonjour et bienvenue à mon ami d'outre-Atlantique! Need a lot more info on what the goal is and what you are working with. What car? Did it come...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
9
All that carpet will have to be ripped out and replaced. There is no other way around it to get it done properly. Seal both sides of the...
17
cam1134
cam1134
Lakeland, Florida
gckless
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
