Bash 500W Digital Subwoofer Plate Amplifier + Home Theater Setup..?
  • 3
LongDongKingKon
20
Bash 500W Digital Subwoofer Amplifier
www.amazon.com/Bash-500W-Digital-Subwoofer-Amplifier/dp/B000CCSX5A/
500 watts RMS @ 0.5% THD into 4 ohm load
Im setting up a Home Theater System and using some old car subs for my HT audio setup..
Would this amp be good enough to power 2 Phoenix Gold 12" subs: 200w RMS - 400w MAX - DVC 4 ohms..?
What would be the best wiring scheme to set them up in using this amp: series or parallel..?
would this setup work..?
have any of you ever had any experiences with these type of amps and car audio subs setup inside a house..?
you need to worry about what the amp puts out and what the speaker's resistance is. you don't need to worry about the resistance of the pre-out (other than the resistance of the wire used to get the signal from the AVR to the amp). just the same as installing a car system.
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
LongDongKingKon
LongDongKingKon
jco1385
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
