Battery: 2002 Ford Explorer SportTrac : Biggest Dimensions to fit under hood?
  • 2
TheGDog
21
OC, CA
What are the biggest Dimensions to fit under hood?
I'm looking to replace my Duralast Gold 850 under the hood with the biggest Kinetik (or possibly another brand) battery that will fit into the stock Battery location without me having to modify the battery mounting location at all.
The Duralast Gold 850 on Autozone shows a 12+1/16" Length and Height and Depth measurements of 7+9/16".
But I checked Autozone today and noted a new Duralast AGM offering which they now list as compatible with my vehicle... however, the dimensions on that one were 12+1/16" Length, 7+3/8" Width, 7+11/16" Height.
So I was hoping I could ask this question here on these forums and hopefully another SportTrac owner who'd gone thru this could tell me without-a-doubt which bigger aftermarket (Kinetik) battery would fit in the stock Battery location without any (or minimal) modification.
Thank you for the pics. However... this does not help me with my original question of what is the biggest (i.e. most powerful) battery (AGM aftermarket) I can find that will fit in the STOCK battery tray of a 2002 Ford Explorer SportTrac. I have no desire to modify the stock battery tray as it appears you've done here.
Though it is hard for me to tell that as your vehicle is significantly different under-the-hood then mine.
TheGDog
TheGDog
OC, CA
TheGDog
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
