No audio from door speakers after replacing battery.
alohaustin
CarAudio.com Newbie
Kauai
I’ve replaced my battery multiple times before, but this is the first time this issue happened.
I have an alpine era g320 eq connected to an amp going to an kenwood deck Along with a subwoofer with its own amp. Funny enough they both have power but only the subwoofer has music sending through. I already checked fuses on the brain of my equalizer along with the amp connected to it.
Any help would be appreciated.
Sounds like my DSP when it is reset to default mode. i.e. instead of all settings going ot "zero", it'll apply crossovers to some channnels, etc.
Maybe your Alpine literally got confused and turned off the output for the front amp (which would tie in to Jimi's idea of resetting things).
Have you tried resetting the HU?
Yeah I factory reset HU. Not sure how to factory reset EQ
yeah this sounds like the case. I’m trying to figure out how to factory reset the eq today
Ill check it out. I was actually on the site last week. Thanks!
217
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
260
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
676
alohaustin
CarAudio.com Newbie
alohaustin
Kauai
Buck
just call me KeV
    Apr 27, 2024
just call me KeV
    Apr 27, 2024
Latest topics
