Battery decision
Davecubs14
Madison, AL
I'm probably gonna get a AQ2200 and feed it to my HDC3(i'm sure it would run better on it than on the 1200D I have). Now. I have a blazer, 105 amp alt. What size battery should I look for? And how do I figure out if it would fit?
So any opinion on what to get? I was thinking a kinetik 1800 or something but not sure if it can handle 2000 watts by itself or be able to fit.
I don't really have a budget, something fairly cheap. let's say around 250 I guess.
Would also accept offers off of here.
with 250 bucks u might be able to pick up two used or new spv70's on here for around 300 shipped that will give u around 140amps per hour and should do the job.
one might do the job i got one in the back, stock 130amp alt, big 3, duralast gold upfront, 1/0 ground and power to the back, battery spv70 with a zx1500@2ohms and a zx850.4 drops to mid 12's at idle with lights on lights off high 12's to low 13's
Yeah, i'll probably measure and see if I can fit which stinger or kinetik battery(or w/e brand) would fit.
If I have to do 2 batteries, I will. I just want to push my sub very well and don't want to have voltage problems and starve the amp. right now I feel like my sub isn't getting pushed at all, and if I turn the gain up too high to give it a push, it starts clipping.
I figured I could ask on here and see what other blazer owners have.
i ran the 2200 with a RT under the hood and a batcap 2000 in the rear(no big 3)
saw 14.2-3 at the lowest //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
miss that amp....
miss that amp....
hmmm I could run a batcap 800 up front and the 2000 in the back. But if I could, I would avoid getting a second battery. So you don't think I could run it with just 1 batcap 2000 or something along the same lines? I've done the big 3 in 0 gauge.
Ok. So I might act like i'm slow after asking this question but i'm not.
I have a battery that does 600 CCAs. Would buying a batcap 2000 or something and put it in the back handle 2000 watts?
I guess i'm just thinking, maybe I shouldn't replace my front battery, just put one in the back. What do you guys think?
Davecubs14
Davecubs14
Madison, AL
pawn man
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
