Battery, DOWN4SOUND | JP-2HC - Hybrid Capacitor, or NVX XCAP10H True 10 Farad Stiffening Hybrid Capacitor
  • 5
Honestly I would try it without electrical upgrades first. In my experience sometimes factory electrical is good enough to run 1500 watts, especially since you won't really be getting that power in daily conditions. You'd need to have your volume up so high that your 4 channel and your sub amp are both right below clipping and you're sending high-mean-power signals to both amps, which basically never happens.
If you do have lights dimming or early clipping, then I would upgrade. Easiest choice IMO is an XS power battery under hood. D3400 is good for 2.5-3k if you can supply the current and in my experience it will absolutely do it. I have 2x d3400 handling 5.5k+ daily with like 0.2V drop.
Of the choices you listed, I'd add the second battery if you really need it.
What the ****? Are you trying to put ohm's law into very complicated verbiage?
974
I like the way these look. But whatever I do it has to be top post. My battery is on the driver side and right beside the air filter housing. So...
676
If your audio system constantly draws more amperage than your alt produces, it will drain your battery, to the point of the battery needing to be...
14
AnthonyO
Budget Banger Connoisseur
AnthonyO
Minot, North Dakota, United States
DEW123
    May 7, 2024
DEW123
    May 7, 2024
