Battery Drain when car off
  • 3
emr214
My brother's girlfriend installed her amp, sub, and head unit herself b4 we knew her and ever since then she must remove the fuse for her amp when she turns the car off or the battery will drain and end up dead. Is this an issue with how the amp is wired to the battery or an issue with the turn on wire coming from the head unit. Full disclosure, I don't know very much about electric wiring or car audio. Thanks for your help.
It's because the remote wire (turn on lead,remote wire) is connected to a hot 12v - meaning the amp is getting a turn on signal constantly from the battery. Car turns off, amp stays on.
She needs to wire it to an accessory that turns off when the ignition is turned off, or wire in a switch.
Props to the chick for doing her own install
If your audio system constantly draws more amperage than your alt produces, it will drain your battery, to the point of the battery needing to be...
14
No. Your factory head unit, if functioning correctly, will consume only a very tiny amount of power (to keep your radio presets and clock...
934
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
460
emr214
emr214
Baltimore
Falcons
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
