Best sounding/highest power 3.5's?
superquest
My 86 Olds 98 sedan takes 3.5's in the dash. I want to power them up with a amp and the 2 highest power RMS taking 3.5's I've found are by Infinity called the Kappa32.9cf which will hold 35 watts RMS, or by Polk called DXi350 which also hold 35 watts RMS. I'm gonna go with a Kicker or Rockford 40x2 amp. Which 3.5's of the 2 would you go with?
Here's the spec pages:
Kappa 32.9cf - Infinity
DXi350 - Car | Polk Audio®
I have an 85 Olds Delta-88 Royale, and I've been through lots of 3.5's. The best I found was Boston Acoustics FE3 (discontinued) or SE35. Don't bother amping them, just use a 150 or 300 hz bass blocker off HU power. 35 watts rated is about the max any of them go, and I've blown 3.5s just on HU power.
If your dash is like mine and the speakers are high up near the windshield you'll have to modify the grilles to mount coaxials cuz the tweeters stick up too high. And the bigger magnets can be tough to squeeze in the holes. If you can fit something other than standard car type 3.5's in there you might look at Madisound web site for home speakers instead.
You want the best? Or you want the best for around that budget? Because there are some outstanding 3" drivers out there.
Audible Physics nz3
Hybrid Audio L3
etc.
Dayton Audio has a bad arse 3" full range for like 20 bucks each on PE.
Audible Physics nz3
Hybrid Audio L3
etc.
Running tweeterless in stock locations could get messy, eh?
Unless he ran a capped tweet too
The NZ3's come with a HF transducer. My buddy runs them without the transducer in the stock dash spot and you'd never know he was sans tweeter. Besides, most 3"ers will go to 15khz or higher. And I doubt anyone would miss anything over that. Heck, people with off axis tweets probably don't get 15khz anyway.
The GOOD thing about the dash spot is it will catch all of the beaming frequencies and reflect them. Whereas a kick or door spot, you might not get that HF extension.
Why worry about RMS power at all? Small mids don't need a lot of people to get moving. Personally, for a good SQ build I would have preferred to have a higher quality 2-way component set installed with the tweeters placed in the mid locations. There just aren't that many good 3.5 coaxial speakers with their flimsy crossovers, and such. Of course, for an average build, to replace blown stock speaker, I'd consider simly a 3.5 inch coaxial speaker. Considering the reputation of Infinity tweeters, I'd prefer the Polk Dbs probably.
I've got 2 sets of these on special for $120 shipped, while supplies last.
How do those sound?I may be interested in a pair.Dont mean to jack the thread, but those look pretty amazing to be able to hadle within the midrange area as well as the tweet areas.
If Infinity speakers have unnaturally bright treble, the ES-02s are the opposite. I prefer mine with a small tweeter, which I changed from silk to aluminum for even more "bite". I'm using them from 1 kHz to 6 kHz and they never disappoint.
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
712
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
613
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
786
Search Amazon for the Dual DCPA701W I had it for about a year and it sounded and worked flawlessly. It was very clean sounding, especially for a...
16
superquest
superquest
Pataskala,Ohio
trumpet
