Best way to fill in parts of dash bezel?
  • 3
jpinusmc
Not sure if this should be here or in the interior part, but since I am doing an install, I'll put it here.
Looking to fit a double-din deck into this single din bezel. I will be cutting upwards into the section of holes right below the heater vents. My questions are:
What is the best material to fill in the holes and make the bezel complete?
Should I fill in the holes first and then make the cutout for the deck or should I make the cutout and then fill in whats left?
Thank you!
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif Also I would recommend sanding the plastic a a ouch to give the resin some grooves to adhere to. As for painting your best bet is to take the dash into a local paint shop and see if they can help you match it.
yes
SI makes nice subs. I'm an XBL guy myself, but I tend to listen to neutral/flat sounding drivers in general.
17
679
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
599
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
534
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
9
675
Search Amazon for the Dual DCPA701W I had it for about a year and it sounded and worked flawlessly. It was very clean sounding, especially for a...
16
jpinusmc
jpinusmc
Lebanon, Or
frogcase2002
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
