Best way to mount MDF spacers in door?
You plan on mounting them to the door panel or to the metal frame?
My old car saw MDF door pods mounted to the door panel with screws (and washers) going thru the panel into the MDF and then the door panel remounted to the door frame.
I believe parts express or Cruthfield sells plastic speaker spacers.
I would do a deep countersink into the rings and then run some self tappers through the predrilled holes into the door. Put down some silicone or preferably clay between the ring and the door and you're done!
the metal frame
Just use silicone or rope caulking for the air gasket between the ring and the metal.
Also, if you can, coat the MDF in fiberglass resin or liquid deadener to seal it. Better yet, don't used MDF at all...solid birch ply, hard plastic or some other solid material. Something like HDPE (aka cutting board plastic) or equiv will hold screws better and is waterproof.
Good advise
i didnt like that clay ****...in the florida heat some of it kinda melted and ran down my door panel.
That's because that "clay ****" is not all the same. The clay YOU used was probably wax-based and only good to about 150* F. A door can get that hot, esp in Fla. Alumilite has the highest temp rating I know of...and it's synthetic-based.
Also, why would one put a soft decoupler between a mounting ring and a solid surface, anyway? Solid - wax - solid? Makes no sense. (just a general q for the audience, not specifically the quoted).
Why decouple the ring at all? I can see air sealing it, but then that would equate to the clay being packed around the outside edge, not under it.
Lastly, a spacer, regardless of material, is just that - a spacer. It will only function as a baffle when certain requirements are met.
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
691
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
583
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
751
Search Amazon for the Dual DCPA701W I had it for about a year and it sounded and worked flawlessly. It was very clean sounding, especially for a...
16
Pickler
Pickler
Las Vegas
Pickler
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
