big 3 question(pics included)
ccab
For The Horde!
Whenever I do the big 3..and im connecting to the fuse holder. am I supposed to use the same fuse holder I already currently have or am I supposed to use two?
pics are including(these are recent) this is just the basic system setup.(bat to fuse..other end of fuse is the wire that comes out to go to amp etc..)
i dont use a fuse holder //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Are you asking if your supposed to use the same fuse holder for your alt to battery wire and your main amp power wire? No you should have separate fuse holders for both wires...
you should not fuse the batt + to alt.
Why would you add resistance to the wire... isnt lowering resistance what the big 3 is all about? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
so I need two fuse holders..and two fuses..one for the big 3 upgrade and one for the basic system.
no dude dont fuse the big three wire its a waste of $$$$$$$$
so just run it with my main system setup? im so **** confused.//content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
All jokes aside, I figured it out. I took the plastic cover thing off of the negative battery terminal, and I can attach a new ground wire right...
37
4K
Probably not gonna get started on that till after the new years really end of February. Working 40hr work weeks right now makes money very tight...
8
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
ccab
For The Horde!
ccab
Southern Georgia
Chrispy
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
