Birch vs 3/4 MDF SPL box
So your saying that Birch is acoustically equal to or superior than MDF?
Depends on the driver being used and the type of Birch and the ear. I assume you are referring to critical listening in the higher frequencies. A driver surrounded by birch that sounds bright might benifit from MDF, and vice versa..if the driver sounds too muddy, Baltic Birch might be the better choice. Both are very close acoustically. For subwoofer duty, Baltic Birch is the strongest and lighter of the two, assuming material thickness is the comparison. As far as true noticeable acoustic differences, try Solid wood vs MDF.
Also, don't get birch from a hardware store like Lowes or HD. Their Birch is not void free, it can be ordered by they will rape you in charges for that. You are better off finding a lumber yard that will allow for direct sales.
this....I even got a piece from a small local lumber yard that was the worst I've ever seen, looked good from the edges but once cut the layers were practically peeling apart. Haven't been back for anything since
Check your wood
I stopped using mdf 2 yrs ago. With birch and aurrco ply.. no predrilling.. no splitting.. sooo much easier to handle a full sheet alone. Takes Louisiana humidity so much better. Definitely stiffer to. Ive had zero complaints or notice a difference in sound either. And the aurrco ply is usually under $30 a sheet.
Yes and no.
---------- Post added at 11:58 AM ---------- Previous post was at 11:58 AM ----------
I would check the Birch. Most "lumber stores" do not have void free wood.
^this....if it is just some birch plywood that you have and are unsure of the glue/layer quality used then I would not use it. I would buy new, or go with the MDF you have.
I have some really nice birch board at my house now too. I'm going to go with the birch and see how well it holds up and if it doesn't, Ill go with MDF. The birch I have now doesn't peel layers at all and cuts pretty well
Chances are if it is not in a 5' x 5' sheet....it is not russian baltic birch which is void free. It is also not cheap. for a 5x5 sheet, you are looking anywhere from $75-$100 a sheet - for 1".
You can get 4x8 sheets of void free birch, but it extremely rare.
Thing that kills me though is whenever I am using my jig to cut the sub hole on mdf, the dust covers up the line im trying to follow and drives me nuts when I have to stop every 4 seconds to whipe to dust away hahaha
use your lungs to blow away the saw dust covering the line while your cutting , thats what i do . hope i could help
yeah, that's what i try to do but sometimes it just builds up so much so quick that it doesn't all come off
It's the same birch board that home depot carries but at $80 a board. Lumber yard out of town has the same stuff for $32
Get a router with a circle jig and hook said router up to the dust collector.....fixed //content.invisioncic.com/y282845/emoticons/suave.gif.858fc102f7646e678ee8af7e1fbc41d1.gif
Yep.
Grab one of these and you're all set //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
G0562Z 3HP Double Canister Dust Collector.
Even ones like this will get the job done for a week-end warrior.
http://www.grizzly.com/products/1-HP-Wall-Hanging-Dust-Collector/G0710
http://www.grizzly.com/outlet/1-HP-Light-Duty-Dust-Collector/G1163
17 layers and it's worth it. Get the Russian stuff if you can. $206 per sheet in Vegas these days.
25
5K
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
4
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
xSPLoder
o_0
xSPLoder
The Roc, NY
disturbed471985
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
