AudioAnonymous 10+ year member
Just use both. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Depends on the driver being used and the type of Birch and the ear. I assume you are referring to critical listening in the higher frequencies. A driver surrounded by birch that sounds bright might benifit from MDF, and vice versa..if the driver sounds too muddy, Baltic Birch might be the better choice. Both are very close acoustically. For subwoofer duty, Baltic Birch is the strongest and lighter of the two, assuming material thickness is the comparison. As far as true noticeable acoustic differences, try Solid wood vs MDF.So your saying that Birch is acoustically equal to or superior than MDF?
this....I even got a piece from a small local lumber yard that was the worst I've ever seen, looked good from the edges but once cut the layers were practically peeling apart. Haven't been back for anything sinceAlso, don't get birch from a hardware store like Lowes or HD. Their Birch is not void free, it can be ordered by they will rape you in charges for that. You are better off finding a lumber yard that will allow for direct sales.
I take it birch cuts better and easier than mdf..??i used birch once and decided i would never mess with the royal pain in the *** that mdf is.
Yes and no.I take it birch cuts better and easier than mdf..??
I would check the Birch. Most "lumber stores" do not have void free wood.We got it from a lumber store
Yes and no.
---------- Post added at 11:58 AM ---------- Previous post was at 11:58 AM ----------
use your lungs to blow away the saw dust covering the line while your cutting , thats what i do . hope i could helpThing that kills me though is whenever I am using my jig to cut the sub hole on mdf, the dust covers up the line im trying to follow and drives me nuts when I have to stop every 4 seconds to whipe to dust away hahaha
It's the same birch board that home depot carries but at $80 a board. Lumber yard out of town has the same stuff for $32Chances are if it is not in a 5' x 5' sheet....it is not russian baltic birch which is void free. It is also not cheap. for a 5x5 sheet, you are looking anywhere from $75-$100 a sheet - for 1".
You can get 4x8 sheets of void free birch, but it extremely rare.
Get a router with a circle jig and hook said router up to the dust collector.....fixed //content.invisioncic.com/y282845/emoticons/suave.gif.858fc102f7646e678ee8af7e1fbc41d1.gif
