Box design help
  • 3
Quaid_Station
I have 1 DAD BD 12.
It's going on my Alpine mrx-240 at 1,000 rms @ 1 ohm.
My car is a 2005 Ford Focus ZX4.
I need a 2.3 cu ft box tuned to 32 hz. I want 45's in the corners of the box and also a Aero Port.
I need help on the calculations for the box cause cause I don't know what size of aero port I need and messing with 45's and a aero port throws off all the box calculations and to know what dimensions / calculations I need.
This is my last step in getting my whole system done other than installation. So confused so please help... Thank you.
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
885
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
4K
In the meantime you could stuff that port hole with a blanket or some pillows and it would probably sound better, if you want to listen to some...
12
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
729
Quaid_Station
Quaid_Station
huntington, IN
brian502
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
