Making my first box for a single SunDown SA12…a little pointers?
  • 2
mrmex
colorado
The list:
Vehicle : 1997 e36 m3 sedan
Location in the vehicle: trunk buttressed against rear seats, firing forward
Space available (Length x Width x Height): 30 x variable x 15
Subwoofer make and model: SA12 http://www.sundownaudio.com/misc/woofer_measurements/SA_Series_Manual(10-12-15).pdf
Subwoofer Size: 12
Number of Subwoofers: 1
AMP: kicker dx300, 700wrms @ 2ohm
Type of Port (Kerfed, Slot, Aero, etc.): aero
What type of music do you like?: electronic, rap, alternative
Is your goal SPL or Everyday Music?: daily
Tuning Freq (Hz): SD recommened 35hz but will that be good for dub step/trap/rap?
Volume : loud but clean
So I've done lots a of research and ready to make the box. I have sketchup but man it is confusing and ended up using Speaker Enclosure Volume Calculator
Seems to work for calculating enclosure size but I'm a little confused on how to port it correctly.
1. how do i decide what port diameter to get. smaller is shorter which is cheaper but is that ok? according to the website's calc's a box with 1.6 cubic ft will need a 2" x 2.5"port but a 3" length increases dramatically to 6.8"
2. where does the port get installed on the box or does it matter
3. is carpenter/wood glue and brad nails enough to hold the box together?
4. where is a good place online to buy all the little misc parts: terminal cups, carpet etc
5. any other suggestions are very welcome!
TIA
Josh
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
847
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
8
I think it worked .just odd bc it's brand new but I appreciate it man. haven't had any problems yet
4
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
5
mrmex
mrmex
colorado
mrmex
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
