Building enclosure tips
.75 mdf- about $10 per sheet, coarse thread drywall screws, liquid nails, weatherproof silicone sealant, fabric or paint, spray glue, drill and table saw or circular saw are good to have, also, I like to use a rotozip to cut the hole for the sub(s). Always predrill before screwing together....
Well he didnt buy a DCON, so thats not helpful.
Your spec sheet that came with your sub has recommended box sizes, then u make make the box whatever shape you want. Although rectangular is most common
You can use this site to get your final numbers
Subwoofer Enclosure Calculators, Fraction to Decimal, Parallel, Series, Port Length and Volume Calculators
How did I come up with that? LOL
hey, OP do you still need help? I must have read to many posts that day! I can give you some help with your Polk sub.
Build currently on hold, waiting on a custom voice coil. The former isnt tall enough for the new setup. On the plus side the motor has 3.25" of...
30
4K
Damn thats a lot of power. You built that whole thing with no BMS? A balancer is good to add of course but a bms is mandatory. I see people doing...
26
6K
NissanWynner
NissanWynner
Houston, TX
JoshC
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
