Camry kicks and tweeter waveguide
Nice thread. Been reading along. I'm working on some 8" JBL's in my kick panels for mid-bass. It's been mentioned that its hard to get proper air space down there. My car is a 1966 Buick, so I have floor vents where my kick panels are (old school air conditioning. I'll be utilizing this space for my 8's to breath. Have to seal up the inside of the vent with fiberglass/spray foam, but I'm hoping to get some real 'kick' outta them with roughly 350 watts each!
Let them vent. That's true IB and really nice to have.
Yes, definitely won't seal up the whole area. Just sealing up the seams and sidewalls/adding strength. They'll have a vent still (out the big ol' rock solid fender) and a large enough space to really go to town. I have my rings in place but working to install my front roll bar before I can get them glassed in. Downfalls of doing a whole car at the same time...slow, slow, slow...definitely don't want my father welding overtop my woofers...
On and on
If your bypassing the infotainment stuff in the original HU setup, then the LCi7PRO should handle the rest. If you want to retain the handsfree...
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
I am going to have to pull it out of the dash and have a look again to see if the wires are correct. I sent over this with a pro shop many times...
The Camry
Hey, I Try.
The Camry
Western Oregon
The Camry
Decebal
    Jun 10, 2024
