Can someone please tell me what kind of sub this is please I’m curious
  • 4
Plz tell me
19173
ED 13.Av.2
Fs: 23.29 Hz
Qts: .45
Qes: .48
Qms: 7.48
Re: 2.81
Vas: 55.79 L
Mms: 257 g
Bl: 14.81 T*m
SPL: 83.50 dB
Sd: 556 cm^2
Xmax: 28.75 (Physical Linear) mm
Voice Coil: 76MM mm
Power Handling : 1200/1500 WRms
Mounting Depth: 10.05"
Weight: 45 lb
I had two of the Xtreme 12's and they were dual 4ohm. They read at like 3.5ohm per voice coil which is common.
9
Still not convinced? https://gpcaraudio.com/15-dual-high-output-glue-it-screw-it-sub-enclosure/ You can order the box glue and screw kit with...
15
3K
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
8
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
ToweAustin12
CarAudio.com Newbie
ToweAustin12
Dawson springs Kentucky
1aespinoza
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
