can someone tell me
  • 5
I just want a 16 v set up on music and keep my 12volt going to my vehicle im try to run 2 tantric HDD 15s on 2 3k amps. Does it add more voltage?
If you don't know exactly what you're doing, messing with different voltage batteries is probably not a step you want to take. What amps are you running? Do you have a HO alt?
Well I have a xs power 16v s1000 already just want to see the proper way to hook it up..but im goin with 2 atomic 3ks and I have a 250 ho alternator im thinking about going up to a 350
You have an alt that will charge the battery at 16V? Or some way of bumping up the voltage from your 12V alt to charge it at 16V?
Gona need a step down module and a externally regulated alt
---------- Post added at 11:13 AM ---------- Previous post was at 11:12 AM ----------
16v aint **** lol ..any transpo external regulator goes to 20
Are the amps 18v stable? 16v batts charge at 18v...just like 12v charge at 14 and 14 charge at 16 and so on..im not sure about running 16v batts @16v not sure if it would cause a problem...maybe someone else can chime in
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
8
I had two of the Xtreme 12's and they were dual 4ohm. They read at like 3.5ohm per voice coil which is common.
9
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Still not convinced? https://gpcaraudio.com/15-dual-high-output-glue-it-screw-it-sub-enclosure/ You can order the box glue and screw kit with...
15
3K
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
tantricbanger2k
tantricbanger2k
Baton Rouge La
tantricbanger2k
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
