Car Amp Repairs
Zach i sent you a pm about 2 amps i need repaired. Haven't got a response? Are you not taking any work now?
Yes im not taking anything at the moment im to busy with school.
And to everyone that is sending me pm's I haven't had time to respond. Im very sorry.
I hate working these mega amps....
That said - there is a good chance that the Curie point of the transformer in question has been affected. This means that the magnetic properties of the transformer have been degraded by excessive heat and that the core must be replaced. What then happens is that the magnetic flux in a push-pull power supply "walks away" from being centered and a DC offset will result. This DC offset saturates the core and causes the FETs to excessively heat - usually just one bank of them - and only past a certain current draw. By the way, this can also be caused by an open rectifier on the secondary side. If you 'scope the transformer's primary, you'll see a huge negative voltage spike that will take out the FETs in short order.
Good luck. You are amazingly brave to have worked on this amp.
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
411
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
581
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
828
I was browsing parts express. It seemed like around $180 for a 300 watt plate amp. The dimensions are not identical, new amps seem larger by a few...
5
zach90z
zach90z
East Amherst, NY
Timmothy Web
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
