Car wont start now...
So I did what you said with the jumping the car and all and here is what happened:
I had a buddy jump my car for about 2 minutes than I started driving it around. About 3 minutes later as I start to slow down to a stop it shuts off on me. Luckily I throw the clutch down and I easily start it once more. I've started to drive it around now and every few minutes it does that same problem. Than it does out completely on me. I can't turn it back on. It once again does the clicking noise and wont turn over. My buddy comes again to jump the car but this time it wont jump. It wont turn over, is it the alternator? Maybe a blown fuse? Any past experiences?
I had a situation just like this on my 76 blazer. I used a battery adaptor to hook up the battery to the amp and the adaptor bolt on the battery threaded out on me and my battery wasnt taking a proper charge and as a result my truck wasnt getting as much power as it should and i had to have my buddies jump me to start once before figuring out that piece of **** adaptor had threaded out. check that battery adaptor. it looks a bit half assed and not on properly in the picture. Get that 100% solid on have your buddy jump you again and if it starts let it idle while holding it above idle to get that battery full up as long as neccessary. Just my 2 cents hope it was helpful.
Your battery is shot. Go get a new batt and you'll be fine.
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
181
A Link would be very helpful. Id be interested in taking a look at some gear
191
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
639
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
Fir3controlman
Fir3controlman
Northern Virginia
ahole-ic
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
