Lbetts818
I know this is kind of opening a Pandora’s box here, and the answers will probably be 50/50. But currently I have two runs of positive and negative front battery to back battery. It’s that time of year where I start cleaning up and fixing things that took a beating last summer in my truck waiting for it to get warm out and was thinking(which can be dangerous) about making all 4 runs into positives and grounding amps and batt in the rear to the chassis. 4 runs would probably be over kill. Have a singer 270a alt, big 4, huge Duralst agm under the hood, juice box yellow battery in the rear. Amps will be a (don’t judge we’ve all owned ct sounds and are not proud)ct 75.4, a c1100.4 and a ia 20.1 wired in the dirt at.4(no I do not need to be told that’s too low, the amp will take it) I’m just curious if you guys have better voltage with dedicated grounds or chassis grounds. Thanks in advance for the info.
