Chassis vs dedicated ground runs
Lbetts818
I know this is kind of opening a Pandora’s box here, and the answers will probably be 50/50. But currently I have two runs of positive and negative front battery to back battery. It’s that time of year where I start cleaning up and fixing things that took a beating last summer in my truck waiting for it to get warm out and was thinking(which can be dangerous) about making all 4 runs into positives and grounding amps and batt in the rear to the chassis. 4 runs would probably be over kill. Have a singer 270a alt, big 4, huge Duralst agm under the hood, juice box yellow battery in the rear. Amps will be a (don’t judge we’ve all owned ct sounds and are not proud)ct 75.4, a c1100.4 and a ia 20.1 wired in the dirt at.4(no I do not need to be told that’s too low, the amp will take it) I’m just curious if you guys have better voltage with dedicated grounds or chassis grounds. Thanks in advance for the info.
I saw a test years ago that showed a frame chassis was good up to around 7-8k
After that dedicated grounds improved voltage drop
Iirc it was between 3 and 4 runs that the chassis was
But that was not a unibody car so take that into consideration
Either way you are only running what 4K?
2 pos 2 neg is more than enough
On big builds I always bolt my big three grounds to the frame up front by the engine and then run ground lines off of the same bolts I used for Big 3 / up front grounds two rear battery usually same number of runs of ground as there are positive that away alternator upfront battery and rear battery Bank are all grounded to the same place on the frame and engine block and all grounded to each other
Issue with going right to the frame is it’s michigan. There’s all kinds of salt and water in the winter and will be replacing wires and lugs on annual basis if going that route. Thanks for the input though guys. I’ll probably just leave it how it is and run it. I was just thinking 2-3ft long grounds would be better than 17-20ft grounds.
Thank you for your reply, your solution is great, however I'm really wondering why there is no dedicated button or even a quick access on the...
Single ground. If there is one thing car audio proves it's that the saying "Ground is ground the world round" is complete BS.
477
I'm guessing that's what it is. There's not a lot of room back there.
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
Lbetts818
Lbetts818
Midland mi
Lbetts818
