Clipping(?) with two 12" Pioneer subs
I set my amp gain the other day by calculating the rms watts of the amp multiply by the ohms you are running at, find the square route of that then with subs disconected and volume at 75% played a 50hz bass note, put the meter across the terminals and turn the gain untill you get your reading of your calculation, mine was 42.42 on a 1800w rms amp gain was set just above half way when it read correct, and it made a hell of a difference as aposed to doin it by ear.....hope this helps you....
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
11
713
Don't recall off hand. Both single dins. One excelon, one not.
927
1. make sure you wired your subs right... https://jlaudio.zendesk.com/hc/en-us/articles/204374200-Dual-Voice-Coil-DVC-Wiring-Tutorial 2. set...
10
Even a basic TL072 will do this function just fine. LoL. The joys of comparators!
34
5K
I would pull the HU and bench test it. Can be done with a 12v battery on a non-metal work bench easily enough.
16
issvor
issvor
Texas
CDE219
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
