Coil Pics Thread
pics of my Alpine type X coil... wasnt burnt by me....
ok need some help here... if i make the exact coil size using the exact winging (length etc) [luckly one of the coil is just black but still has its original winding intact which i can copy]
so would it sound any different from the original?
also wat glue or paste should i use on top of the coils to keep it cooler? (the original coil has some aluminium sheet type thing over it.)
also i have a blown jlw127. i know the gauge of the wire, but dont not know the length of the coil.. and everytime i recone it , it either sounds bad , hits the bottom or is not 3ohms.. ..... does anyone know the length of the coil? also if i try to make a 2ohms coil on this jl12w7... what will be the drawback? will it sound the same as original?
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
492
Not a term, a description. When it clips, it sends a distorted signal (current) through. A square wave contains more energy than a sine wave and...
27
Okay i found one under b stock on alphards shop site but unable to actually place order grrr
w00tah
Captain Keffa
w00tah
Z-Ville, OH
enerlevel
    May 18, 2024
    May 18, 2024
