Component speaker location and orientation
  • 1
analogfreq
CarAudio.com Newbie
I am thinking of installing some component speakers into my truck, and have been considering the locations for a while now. Thinking of 2 way, but possibly 3 way.
I think the tweeters will sit well right below the dash, on some panels (side kick?) They have a direct line to the ears. Because of the shape of the door, all the angles, and the lower part of the dash, there may be some horn like gain at this location. I am not sure if this is good or bad.
The 6.5 mid-woofers can install in the doors, in a 'standard' location. This will have the tweeters sitting a little above the MW's, and at an angle that crosses them at maybe 70 degrees. Obviously, different frequencies.
Is is a bad thing that these drivers cross each other in orientation?
There will be active processing before the amps, including delays.
Thanks for any help.
Thanks so much guys. Talked to crutchfield support with the same question and although they likely don't know everything, and sometimes, salesmen...
6
I can hear the difference. A typical component system will have a superior tweeter and crossover, although I've noticed component crossovers are...
analogfreq
CarAudio.com Newbie
analogfreq
Sandpoint, ID
analogfreq
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
