Crimping 1/0 Ring Terms and Testing Ground question
Don’t bother smashing or crimping it
You need to solder it; you need more heat, lots of heat
Do not heat the solder, heat the connector until the solder melts into the wire
A 1/0 connection will take lots of solder
Don’t bother smashing or crimping itYou need to solder it; you need more heat, lots of heat
x2 Heat the ring terminal just below the eye hole on the back. then put the solder on the other side of the ring terminal it will melt and flow into the wire. The best way to do it though is to crimp it and solder it.
Had a set of Ecplise 6x9's back in the day in my '99 Grand Cherokee. The SE8495s iirc those were so sweet sounding. Wish I hadn't sold the GC with...
I have never heard SP Audio. From what I have sampled, it seemed that the DB Arnolds sounded the most detailed. Then again, they were auditioned...
That's subjective. Personally, I find the hot/shrill sound produced by the comb filtering to be unbearable, so I wouldn't even listen to the...
20
3K
covmaster
covmaster
Los Angeles, CA
grimreper912003
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
